ETI FS-08 Pure silver RCA Connectors (Pair)
These FS-08 RCA mounts from ETI-Research are RCA sockets based on the same principle as the FR-TC07 model. High-quality, they feature a pure silver conductor and a silver-plated copper ground. This ensures maximum conductivity and resistance to corrosion and oxidation.
Reference : 18741
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 25-04-2025.
ETI FS-08 Pure Silver RCA Connectors (Pair)
Photo of ETI FS-08 RCA sockets
These FS-08 RCA sockets from ETI-Research are RCA sockets based on the same principle as the FR-TC07 model. High-quality, they feature a pure silver conductor and a silver-plated copper ground. This ensures maximum conductivity and resistance to corrosion and oxidation. The FS-08 model, like the FR-TC07, replaces the Phono pod. Here are the main advantages of the FS-08 RCA connectors:
  • Ultra-low mass for improved transient response and soundstage.
  • Polymer shell for complete chassis isolation.
  • Pure silver signal pin with curve for easy soldering.
  • Brass locknuts to absorb vibrations and reject EMI/RFI interference.
Diagram of ETI FS-08 RCA socket dimensions
Technical characteristisc
Product typeRCA sockets
Contact materialPure silver
Locknut materialBrass
InsulationPolymer
Total length30mm
Max. diameter15mm
Drilling diameterØ12mm with washers
Ø10mm without washer
Max. panel thickness4.5mm
PackageSold by pair
Mounting typeTo weld
Max panel thickness (mm)4.5
Contacts Material (Connector)Silver
These FS-08 RCA mounts from ETI-Research are RCA sockets based on the same principle as the FR-TC07 model. High-quality, they feature a pure silver...
