FURUTECH FP-908 (G) PCB RCA inlets Gold plated Pure Copper (Pair)
By buying this product you get 36 loyalty points
Reference : 10418
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 17-04-2025.
These Furutech bases made of pure copper, machined in the mass and gold-plated, offer an exceptional level of conductivity.
The vast majority of audio connectors are made from brass or bronze / phosphor alloy with a conductivity typically less than 28% IACS (International Annealed Copper Standard).
By way of comparison, the high purity copper (OFC) used in most interconnection cables at a conductivity rate of 100% IACS.
EBecause of the use of these "low" conductivity alloys, the majority of even expensive RCA sockets tend to decrease the performance of the cables to which they connect.
Features:
  • Contacts in pure copper treated Alpha machined in the mass
  • Gold Plated
  • Insulation: Nylon + fiberglass
  • Welding
  • Application: PCB / printed circuit board
  • Max. Diameter of the base: 17 mm
  • Length of the base: 34.5 mm
  • Height: 21.1 mm
Mounting typeTo weld
Max panel thickness (mm)3.5
