I used these RCA sockets in my tube DAC. Their quality is fantastic and since I haven't compared them to other sockets directly... The overall sound of a DAC is top notch.
These Furutech FT-903 (R) solid-copper and Rhodium plated base plates offer a record level of conductivity and a flawless signal transmission.
The vast majority of audio connectorsare manufactured from brass or bronze / phosphorus alloys with a conductivity typically less than 28% IACS (International Annealed Copper Standard).
By way of comparison, the high purity copper (OFC) used in most interconnecting cables has a conductivity of 100% IACS.
Due to the use of these "low" conductivity alloys, the majority of even costly RCA sockets tend to decrease the performance off = "http://www.audiophonics.com/en/cable-et-cordon-c-1327.html" target = "_ blank">cable to which they connect.
These FT-903 (R) sockets are the result of the meticulous engineering of Furutech, with particular attention to the materials and components used.
Main Features :
Mounting type |
Max panel thickness (mm) |
Contacts Material (Connector) |
Contacts Plating (Connector) |
Average votes 4.2 / 5 5 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Srboljub S.
Erwin S.
Alain A.
david P.
Daniel E.
