This connnector allows you to quickly add a robust RCA connectivity on your boards.
It has a perforation front size M2.5 screws to ensure robust and sustainable arrangements in time.
Type | RCA connector |
Canals | x2 |
Color code | Red Black |
Mounting Type | soldering printed circuit. |
Dimensions | 30 x 20 mm (without pins) |
Weight | 6g |
Mounting type | To weld |
Max panel thickness (mm) | N/A |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | None |
