RCA plug modified to be balanced (three pins), backward compatible with standard RCA cables and plugs. The third pin allows transmission of a inverse analog audio signal, for use with balanced audio equipment.
Backward compatible with conventional RCA sockets (single-ended).
Specifications | |||
Type | Custom RCA plug (balanced) | ||
Contacts | x3 (balanced) | ||
Backward compatible with standard RCA | Yes | ||
Mount | Weld | ||
Plating | Gold | ||
Connector body | Brass | ||
Color | Red |
Mounting type | To weld |
Max panel thickness (mm) | N/A |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
