KLEI CLASSIC HARMONY RCA Plugs Silver Plated Copper (Pair)
The RCA KLEI Harmony Classic RCA bases offer excellent design quality for enhanced performance, based on a certain know-how, the fruit of the brand's many years of experience. For example, the contacts of these sockets are made of copper with silver plating, ensuring an optimum conductivity of 101% IACS.
Reference : 14423
41,90 €tax incl.
34,92 € tax excl.
Shipping date: 25-04-2025.
KLEI HARMONY CLASSIC
KLEI Harmony Classic Embases RCA Cuivre Plaqué Argent (La paire)
The RCA KLEI Harmony Classic RCA bases offer excellent design quality for enhanced performance, based on a certain know-how, the fruit of the brand's many years of experience. For example, the contacts of these sockets are made of copper with silver plating, ensuring an optimum conductivity of 101% IACS. The design of these connectors focuses on signal integrity by eliminating the causes of possible interference, such as eddy current or capacitive reactance.
For the body of the subbases, an ultra heat resistant polymer was used, cancelling the disturbances that can be induced by a metal structure. The mass of the connectors is also reduced and calculated by KLEI in order to limit the skin effect as well as EMF and RF interference.
Thus, these mounts will fit perfectly into your high-end DIY setups and contribute to the signal transmission quality of your audio system.
Product typeRCA plugs
Contacts materialCopper
Contacts platingSilver
IACS Conductivity index> 101%
Screw threadM10
Cutout diameterØ10mm
Max panel thickness7mm (without color ring)
5mm (with color ring)
Connection typeTo solder
QuantitySold by pair (1 plug with red ring, 1 plug with white ring)
Mounting typeTo weld
Max panel thickness (mm)7.0
4 reviews
Excelente embases
Trés bonne qualité, le produit est solide. Soudures des fils sans difficultés. En remplacement d'embases défectueuses sur une platine vinyle Pro Ject The Classic.
This review has been posted for KLEI CLASSIC HARMONY RCA Plugs Silver Plated Copper (Pair)
Fiabilité de contact zéro
Très déçu par la qualité mécanique de ces embases, le contact du point se fait par une minuscule lamelle à l'intérieur de la fiche.
Cette lamelle étant trop aplatie contre le corps de la prise, le contact de la fiche se faisait très mal.
Conséquence une panne aléatoire sur l'ampli que je venais de terminer, des heures à chercher d'où venait le problème.
Je précise que je suis fan des fiches rca Klei sur tous mes cables rca mais là ces embases sont pas top.
Bien sûr embases soudées donc j'ai même pas pu demander le remboursement
LIVELLO TOP
Funzionano alla perfezione.
Siamo ai massimi livelli di trasmissione del segnale....
Inalterato...
SUPER CONSIGLIATI
Bon matos
C'est bien fait, et ça remplace avantageusement des embases d'origines en laiton ou bronze plaqué or.
The RCA KLEI Harmony Classic RCA bases offer excellent design quality for enhanced performance, based on a certain know-how, the fruit of the...
