Pure Copper RCA Plugs (Set x4)
The RC-101 from Viborg are very good RCA subbases, ideal for quality DIY assemblies. Indeed, they integrate a pure copper conductor in order to offer an optimal signal conductivity. In addition, the connector has Nylon and Teflon insulation to protect the signal from potential interference.
Conductor material | Pure copper |
Housing material | Brass nut & Chrome plated cap |
Insulation | Nylon Teflon |
Connection type | To solder |
Drilling diameter | 11.3mm |
Housing dimensions | 16 x 12mm |
Total length | 32.9mm |
Mounting type |
Max panel thickness (mm) |
Contacts Material (Connector) |
Contacts Plating (Connector) |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Jonas S.
