1877PHONO CryoGold-Ag Headshell Leads / PC-OCC gold Plated 40mm (x4) 1.0 - 1.2
A set of high quality Headshell Leads for turntable cell.
4.3 / 5
Reference : 12623
125,00 €tax incl.
104,17 € tax excl.
Shipping date: 23-04-2025.
Get the best signal from your turntable
Fils de litz Cryogold
A set of high quality Headshell Leads for turntable cell. The CryoGold-AG range uses a conductor consisting of 99.999% pure silver strands and PC-OCC copper. The conductor itseklf is gold plated to complete the set. All materials are processed at extremely low temperatures (-186 ° C to -196 ° C) and subjected to a patented purification process (Ultra-Sonic7) prior to extrusion and strand forming. This manufacturing method eliminates all structural impurities and formation residues (dust, traces of oil) that can affect the clarity of the signal.
H-WOUND Technology
Cryogold 1877 Phono Audiophonics
Like all Litz 1877 Phono wires, CryoGold also benefits from the H-wound braiding technique, which increases the density of the conductor by reducing the space between the strands spires. These cables are therefore denser and offer increased conductivity but remain as flexible and thin as ordinary cables. This manufacturing process practiced in almost horizontal configuration offers a cable of unmatched quality for an incredible fidelity of the musical message even in the deepest dynamic subtleties.
FitClips proprietary clips are constructed from OFHC-Rhodium-Silver Copper. They are installed on the conductor by hand by professionals following an extremely meticulous process designed to supress any imperfection. Welds use a silver / copper mix to remove the excellent conductivity of CryoGold litz wires.
CryoGold cables will delight audiophiles who want the purest sound for their turntable. These litz wires were designed with perfection in mind, with deliberately exaggerated construction requirements to produce a cable that is absolutely flawless at every level
  • Conductor: Pure Silver 99.9999%
  • Multi-Strand Gold-coated PC-OCC Copper
  • H-wound Twist Construction
  • Cable weight : 0.17g
  • High Frequency Signal
  • Deep-Cryogenic Treatment
  • Color Code : White / Red / Blue / Green
  • Wire Diameter : 0.6 mm
  • Wire Length : 40 mm
  • Connectors : 1.2 mm / 1 mm
  • Connectors already set : yes
  • Sold by 4 wires set
Color Code
WhiteLeft channelPositive
BlueLeft channelNegative
RedRight channelPositive
GreenRight channelNegative
4 reviews
Not a good experience for me
I’m sorry to give a negative review on what seems to be a very high quality and well thought out product, but I have to share my experience. I have used this cables to connect my Benz Micro Glider SL to an Ortofon LH9000 headshell. Compared to the wires that come with the shell (I guess the ortofon 6N headshell leads), the 1877phono ones led to a more sterile presentation, less precise imaging, less threedimensionality and body, bass less controlled, highs a bit fatiguing, less dynamic. The clips on the shell side were a bit too large, but they allowed a sufficient grip on the pins and I don’t think that is the problem leading to the lesser presentation. I think the problem is most likely the rhodium plating. in my experience rhodium plating on audio signal connectors lead to sterile and harsh sound, this is the third time I have bad experience with rhodium, the other two being Ramm spades and Neotech XLR connectors. In all cases I had to switch back to gold or silver plating even giving time to break in. I have all power connector furutech rhodium plated but for audio signal now I’m really done with rhodium, I’ll try no more. To give context I have a Garrard 401 TT with modified SME 3009 II improved, Mark Levinson 26 and 23.5, and Tuscanini planar magnetic speakers (very revealing of any insignificant defect along the audio chain as in this case).
This review has been posted for 1877PHONO CryoGold-Ag Headshell Leads / PC-OCC gold Plated 40mm (x4) 1.0 - 1.2
Probably one of the best
Have a collection of different headshell wire's to compere from, at ,ortofon jelco and so on .
Having used these for a week I say zavfino picked the best quality's from all the other and put them in one wire. Outstanding work!!!
1877Phono
L'amélioration apportée par ces petits morceaux de câble est incroyable. Plus grande définition, profondeur de la scène sonore. La différence se fait entendre dès la première écoute!
Belle amélioration!
Aucun doute sur la différence entre ces cables et des AT cuivre OPCC fournis avec les cellules Audio Technica.
Attendre 2 ou 3 heures de lecture avant d'obtenir le rendu sonore maximal.
Par contre les embouts noirs qui se clipsent sur le porte cellule ont un diamètre trop large...il faut bidouiller un peu pour qu'ils tiennent bien enfoncés (j'ai rajouté un minuscule brin de fil électrique dans chaque connecteur).
