1877PHONO EH-Fusion Mat Vinyl Platinum Absorbent Mat
4.0 / 5
Reference : 8111
36,90 €tax incl.
30,75 € tax excl.
Shipping date: 01-04-2025.
The EH-Fusion is a 1877PHONO accessory that absorbs unwanted vibrations and isolates noise from your vinyl turntable./ P>
In addition, the double-layered design allows its own sound signature depending on the side used and is particularly effective when used on a metal tray.
Features:
  • External Diameter: 295mm
  • Laser-cut absorbing EVA layer
  • Total Thickness: 5mm
  • EVA absorbent
  • Anti-static
  • Non-deformable
  • Resistant to mold and moisture
  • Dissipation Factor: 1kHz 0.03
  • Dielectric Constant: 1kHz 3.1
  • Reversible design
https://www.audiophonics.fr/images2/8111/8111_1877phono_EH-fusion_1.jpg
https://www.audiophonics.fr/images2/8111/8111_1877phono_EH-fusion_2.jpg
5 reviews
1877PHONO EH
Bon produit cependant je n'ai mis que 3 étoiles car le diamètre est le meme que celui du disque ce qui fait que lorsque l'on change de 33 tours le couvre-plateau vient avec.
Donc il faut peut-etre mettre un scoth double-face?
This review has been posted for 1877PHONO EH-Fusion Mat Vinyl Platinum Absorbent Mat
very satisfied
good results against the sticky static effect when handling your vinyl and choice between a sharp dry sound on the cork side or a deeper subtle bass on the black side
Better than others!
I had a similar mat with Cork & EVA (also with round recesses) but it was made less accurate - therefore it "dished" after just a few weeks and would not lie flat any more on the turntable.
This product is much more solid and thighter - also looks and feels much more sophisticated.
bon produits mais caractéristiques affichées fausse
la qualité de ce produit est irréprochable, le rapport qualité prix est bon.
Cependant, il n'as pas convenu a mon besoin. Les caractéristique annonce diam 295mm et épaisseur 5 mm.
Il se trouve que le plateau de ma platine vintage est creusé et les 295 correspondait .
Hélas, quand je l'ai posé, cela ne rentrait pas, je donc du le retailler.
une fois posé surprise, pas assez haut, après mesure... épaisseur 3 mm. Je ne peux donc pas l'utiliser.
Très beau produit , pas déçu , amortissement excellent .
