Litz Wire Pure Silver 0.1mm² Cryo Treated 60cm (x4)
Here is a set of 4x Litz wires by 1877PHONO. Constructed of 99.999% pure silver and measuring 60cm each for a 34AWG section (0.143mm diameter).
These Litz wires are assembled using the manufacturer's own H-Wound Enamel method, ensuring a compact winding of each strand with durable effiency and a constant build quality so as not to unbalance the listening experience when renewing the Litz wire.
This process is particularly long and difficult to implement since it is has to be practiced in a quasi-horizontal configuration. Yet it ultimately makes it possible to obtain a cable free from any defect and capable of reproducing the musical message down to its smallest details.
Each conductor is individually insulated by means of a polyurethane film which is itself covered with enameled nylon.
SPECIFICATIONS | |||
Type | Litz wire | ||
Conducteur | 99.999% Solid Pure Silver | ||
Treatment | Deep Cryo™ Ultra Sonic-7™ | ||
| Cross Section | 34AWG | ||
| Coating | Film nylon & polyurethane | ||
Conception | Zavfino’s H-Wound™ Zero Strand Loss | ||
| Core Diameter | 0.143mm | ||
| Weight | 0.104g / 60cm | ||
| Package | 4x 60cm wire | ||
