1877PHONO LYCAN 270G Tuning Puck / Weight for Turntable
Designed and manufactured from a combination of carefully selected materials to reduce, absorb and dissipate external vibrations, this 1877Phono Lycan 270G pressure puck is suitable for platinum bearings up to 6mm deep. It is precision machined from a block of 6061 aircraft grade aluminum for a total weight of 270g.
By buying this product you get 20 loyalty points
Reference : 16321
209,00 €tax incl.
174,17 € tax excl.
Shipping date: 03-04-2025.
1877Phono Lycan 270G Palet Presseur / Stabilisateur pour Platine Vinyle
Designed and manufactured from a combination of carefully selected materials to reduce, absorb and dissipate external vibrations, this 1877Phono Lycan 270G pressure puck is suitable for platinum bearings up to 6mm deep. It is precision machined from a block of 6061 aircraft grade aluminum for a total weight of 270g. Its center ring is made of pressure-fit Delrin and separated by two silicone seals. The Delrin not only dampens vibrations but also protects the bearing of your turntable from wear and scratches due to continuous use. The bottom of the puck is equipped with a non-marking leather pad to further absorb weight and protect your vinyl's label from scratches and scuffs. The Lycan will fit a wide range of turntables to help minimize vibration and keep your records flat on the platter.
Product typeTuning puck / weight for turntable
MaterialsAluminum 6061
Oak insulation disc
Central ring in Delrin (POM) with silicone seals
External rubber rings
Bottom leather pad
Weight270g
DimensionsØ80 x 31mm
Designed and manufactured from a combination of carefully selected materials to reduce, absorb and dissipate external vibrations, this 1877Phono...
