1877PHONO Z-LITZ100 Phono Headshell Leads Litz Wire 24k Gold Plated OFHC Copper 40mm (Set x4)
These 1877Phono Z-LITZ100 cables allow you to wire a phono headshell in an efficient way. Using Litz wire, each strand of each conductor is isolated from the others to limit the skin effect. Moreover, each conductor is made of high purity OFHC copper and 24k gold plated, ensuring excellent conductivity and resistance to oxidation.
Reference : 16415
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 25-04-2025.
1877Phono Z-LITZ100
1877Phono Z-LITZ100 Câblage Cellule Phono Fils de Litz Cuivre OFHC Plaqué Or 24k 40mm (Set x4)
Product typePhono headshell leads
ConductorsOFHC Copper Litz wire
Condcutors plating24k Gold
Length40mm
QuantitySold by 4
Très bien
En remplacement des câbles d'origine de mon bras SME 3009 et raccordés sur une Shure V15 type 4.
This review has been posted for 1877PHONO Z-LITZ100 Phono Headshell Leads Litz Wire 24k Gold Plated OFHC Copper 40mm (Set x4)
These 1877Phono Z-LITZ100 cables allow you to wire a phono headshell in an efficient way. Using Litz wire, each strand of each conductor is...
