CHISTO CONCENTRATE Vinyl Cleaner Concentrate 33 / 45 / 78 RPM 100ml
Chisto Concentrate is a cleaning fluid concentrate for 33 / 45 / 78 rpm vinyl. This cleaning concentrate has anti-static, fungicidal and anti-bacterial properties, you can also clean new discs to remove the MRA (Mould Release Agent) present on them. Before application it is necessary to remove dust, traces and other dirt. This product, intended for routine maintenance of your vinyl record collection, will provide effective long-term protection without leaving residue.
Reference : 17679
24,90 €tax incl.
20,75 € tax excl.
Last items in stock !
Shipping date: 24-04-2025.
Chisto concentrate
CHISTO CONCENTRATE Concentré de nettoyant pour vinyle 33 / 45 / 78 tours 100mL
Chisto Concentrate is a cleaning fluid concentrate for 33 / 45 / 78 rpm vinyl. This cleaning concentrate has anti-static, fungicidal and anti-bacterial properties. You can also clean new discs to remove the MRA (Mould Release Agent) present on them. Before application it is necessary to remove dust, traces and other dirt. This product, intended for routine maintenance of your vinyl record collection, will provide effective long-term protection without leaving residue.
The Chisto Concentrate consists of a spray (100ml) for cleaning. Simply dilute the 100ml bottle in 0.9L of distilled water to obtain 1L of cleaning fluid. With one machine, 1L of cleaning fluid will allow you to clean approximately 1300 vinyl records on both sides. For manual use you can reuse the flacvon in which the concentrate is packaged.
Chisto Concentrate is intended to clean vinyls, remove MRAs, and improve their readability. (Shellac compatible)
Product typeVinyl cleaner concentrate 33 / 45 / 78 RPM
Quantity100ml
Package1x Chisto Concentrate (100ml)
Chisto Concentrate is a cleaning fluid concentrate for 33 / 45 / 78 rpm vinyl. This cleaning concentrate has anti-static, fungicidal and...
