CHISTO SPRAY AND WIPE Vinyl Cleaning Spray 33 / 45 / 78 RPM 100mL
Chisto Spray and Wipe is a cleaning fluid for 33 / 45 / 78 rpm vinyl. This cleaning spray has anti-static, fungicidal and anti-bacterial properties, you can also clean new discs in order to remove the MRA (Mould Release Agent) present on them. Before application it is necessary to remove dust, traces and other dirt. This product, intended for routine maintenance of your vinyl record collection, will provide effective long-term protection without leaving residue.
Reference : 17678
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 10-04-2025.
CHISTO SPRAY & WIPE
The Chisto Spray and Wipe consists of a spray (100ml) for cleaning, an Evolon® silk micro-fiber cloth (washable and reusable), a Duster cloth (for dusting before washing) and a vinyl brush. You will be able to clean about a hundred vinyls on both sides of readings with the contents of this pack.
How to use CHISTO EASY GROOVE SPRAY AND WIPE
  1. Dust off your vinyl record using the Chisto Duster.
  2. Spray the Spray & Wipe liquid on one of the two sides of the vinyl
  3. If necessary, use the applicator brush to make the cleaning liquid penetrate to the bottom of the micro-groove.
  4. Wipe your vinyl record with the silk cloth, counter-clockwise until it is completely dry.
  5. Repeat the operation on the second side of the vinyl.
  6. Store your disc in an anti-static sleeve!
Product typeVinyl cleaning spray 33 / 45 / 78 RPM
Quantity (spray)100ml
Package1x Chisto Spray and Wipe (100ml)
1x Evolon® micro-fibre silk cloth
1x Duster Cloth
1x Vinylbrush
Chisto Spray and Wipe is a cleaning fluid for 33 / 45 / 78 rpm vinyl. This cleaning spray has anti-static, fungicidal and anti-bacterial...
