DYNAVOX TW-4 Digital Stylus Force Gauge 0.01g - 200g +/-0.01g
This Dynavox TW-4 scale is designed to weigh your phono vinyl cells. Thus, it offers a high precision measurement over a range of 0.01g to 200g, with a tolerance of +/-0.01g. It will thus be possible for you to precisely adjust the pressure exerted on your vinyl so as not to damage it, while optimizing the listening experience.
4.0 / 5
Reference : 14902
22,90 €tax incl.
19,08 € tax excl.
Shipping date: 22-04-2025.
Dynavox TW-4
Dynavox TW-4 Pèse cellule électronique 0.01g - 200g +/-0.01g
This Dynavox TW-4 scale is designed to weigh your phono vinyl cells. Thus, it offers a high precision measurement over a range of 0.01g to 200g, with a tolerance of +/-0.01g. It will thus be possible for you to precisely adjust the pressure exerted on your vinyl so as not to damage it, while optimizing the listening experience. This tool is particularly useful, especially for turntable arms that do not have a graduated weight (Rega, Clearaudio, etc.).
The scale support is made of non-magnetic stainless steel. The unit of measurement can be selected between gram, ounce, troy ounce, carat and grain. An automatic shut-off function allows the scale to be switched off after 60 seconds without activity.
Product typeDigital stylus force gauge
Support materialAnti-magnetic stainless steel
Measuring range0.01g - 200g
Accuracy+/-0.01g
Tare function
Automatic switch-off functionAfter 60s
Unit of measure selectionGram
Ounce
Troy ounce
Carat
Grain
Power supply2x Piles AAA (Sold separately)
Dimensions115 x 65 x 16mm
Weight100g
2 reviews
Janezg
Beautifully made and easy to use.
This review has been posted for DYNAVOX TW-4 Digital Stylus Force Gauge 0.01g - 200g +/-0.01g
Plateau un peu grippé
Lorsque je retire l'objet après une pesée, l'affichage ne revient pas à 0. La mesure est erronée. Lorsque j'actionne manuellement le plateau plusieurs fois, la mesure est correcte. Cela n'est pas très pratique.
This Dynavox TW-4 scale is designed to weigh your phono vinyl cells. Thus, it offers a high precision measurement over a range of 0.01g to 200g,...
