HUMMINGURU HG01 Ultrasonic Vinyl Cleaning Machine
The HumminGuru vinyl cleaning machine is an ultrasonic cleaning machine. This machine provides a professional level of cleaning for your vinyl. It's intuitive, compact, lightweight and silent, for pleasant, high-performance cleaning.
By buying this product you get 67 loyalty points
Reference : 18904
679,00 €tax incl.
565,83 € tax excl.
Shipping date: 24-04-2025.
HumminGuru HG01 Ultrasonic Vinyl Cleaning Machine
Photo of HumminGuru HG01 cleaning machine
HumminGuru HG01 highlights
This machine can clean both 45 rpm and 33 rpm records, whether 130g, 160g, 180g or 220g. However, it is not recommended for washing Shellac records (78 rpm), as these are considered too fragile.
How the HumminGuru HG01 works
The cleaning action of the HumminGuru HG01 is based on dual 40kHz ultrasonic technology. This system is used to create bubbles in a water bath and thoroughly clean the grooves of your disc without damaging it. Following the ultrasonic bath, the bath automatically drains into a water tank. A double-ventilation drying process is then triggered to dry your disc equally on both sides.
Ultrasonic cleaning
Ultrasonic cleaning
Automatic draining
Self-draining bath
Double-sided drying
Double-ventilated drying
HumminGuru HG01: a smooth rotation system
The rotation system of the HumminGuru HG01 is made up of two points, ensuring that the vinyl is firmly supported on its edge and not damaged. The two small wheels making up this system can be easily replaced by the user.
Système de rotation de la machine HumminGuru HG01
Rangement facile de la machine HumminGuru HG01
HumminGuru HG01: a compact form factor
The HumminGuru HG01 ultrasonic cleaning machine has a fairly compact form factor, making it easy to fit into your vinyl cabinet. It's also easy to handle, weighing just 3kg.
Operating the HumminGuru HG01 machine
  • Auto mode: in auto mode, you can select two cleaning times, 7 or 10 minutes. You can therefore perform a quick cleaning with a view to listening to your disc. However, if your disc is very dirty or new, a longer cleaning time is recommended for a better cleaning.
  • Cleaning only mode: you can choose cleaning only mode if you don't need to dry the disc with the machine.
  • Drying-only mode: you can run a drying-only cycle if your disc simply needs to be dried. You can set the drying time to 5 or 10 minutes.
Product typeVinyl cleaning machine
TechnologyUltrasonic
Ultrasonic frequency40kHz
Noise level≤ 60/70dB
Drain tank capacity350ml
Disc compatibility33 and 45 rpm (12", 130g, 160g, 180g or 220g)
Power supply100-240V
Dimensions34.2 x 15.2 x 27.4cm
Weight3kg
Package1x HumminGuru HG01 vinyl cleaning machine
1x AC adapter
1x set of 5 filters / 5 air filters / 2 pairs of casters
1x manual
1x maintenance tool
Download
HumminGuru HG01
Instructions for use - FR
Download (2.28M)
Excellente solution pour le nettoyage des vinyles
Rien à dire. Machine compacte, silencieuse (pour une machine à ultrason), pratique. Les disques ressortent comme neuf et cela se ressent énormément au niveau de l’écoute. Prix un peu élevé, mais on reste en dessous de la plupart des autres systèmes existants.
This review has been posted for HUMMINGURU HG01 Ultrasonic Vinyl Cleaning Machine
The HumminGuru vinyl cleaning machine is an ultrasonic cleaning machine. This machine provides a professional level of cleaning for your vinyl....
