By buying this product you get 32 loyalty points
Vinyl Cleaning Machine Carbon
The Pangea Record Doctor VI is the ideal tool to effectively clean your vinyl records to preserve them and promote better sound reproduction. The cleaning fluid is applied evenly to the surface of the record with a high quality nylon brush. The easy-to-handle rotating nozzle protects the record label from moisture at the same time. After application, you can easily remove the dirt with the integrated vacuum function.
Product type | Vinyl cleaning machine |
Dimensions | 315 x 178 x 220mm |
Weight | ~ 4.5kg |
Color | Gloss black |
Package | 1x Cleaning fluid 1x Nylon brush 1x Power cable 1.8m 1x PANGEA RECORD DOCTOR VI |
Color | Carbon |
Power supply | 230V |
