WINYL ONE-TOUCH Phono Stylus Tip Dry Polymer Cleaning System
Winyl One-Touch is a platinum vinyl diamond cleaner containing the latest generation of solid Polyurethane (PU) polymer and specially designed to provide optimal diamond cleaning.
Reference : 14109
27,90 €tax incl.
23,25 € tax excl.
Shipping date: 27-10-2026.
Winyl One-Touch
Winyl One-Touch Polymer Nettoyant Solide pour Diamant Platine Vinyle
The polymer is soft, highly elastic and has a high adhesive capacity, thus eliminating dust and microscopic impurities stuck to the diamond and causing sound distortion. This polymer has been developed in such a way that no residue remains on the diamond, thanks to a dry cleaning system without liquid.
One-Touch polymer is safe and extremely easy to use. Simply place the cell holder on the polymer and slowly lower it until the diamond is inserted into the polymer. When the cell holder is raised, the dirt on the diamond adheres to the surface of the polymer, leaving the diamond completely clean.
In addition, One-Touch polymer is washable and reusable. If the surface of the polymer is dirty after many uses, simply rinse it with water, gently rubbing the surface with your finger, then drain and let it dry. By keeping the One-Touch in good condition, it can be used for several years with the same efficiency.
Product typePhono stylus tip cleaner
MaterialPolyurethane (PU) Polymer
4 reviews
Très bien
Pas trouvé mieux à ce jour!
This review has been posted for WINYL ONE-TOUCH Phono Stylus Tip Dry Polymer Cleaning System
ONE-TOUCH POLYMER
Un produit non agressif qui fonctionne très très bien, avec une brosse ou un produit pulvérisé on croit que le diamant est propre mais le polymer va plus loin, un voile sur les aigus est levé et tout y gagne, très bien.
très éfficace
Apporte une grande netteté à l'écoute mais le son est un peu mat. Je l'associe avec le nettoyant liquide en second passage et le résultat est génial . J'ai l'impression d'avoir une platine de plus haut de gamme . Très recommandable.
Nettoyage efficace et sans agressivité
Ce polymère qui existe sous d'autres marques diverses à des tarifs eux aussi divers et surtout plus élevés permet de retenir les impuretés déposées sur le diamant sans agressivité et avec une réelle efficacité. Pour un résultat parfait je le combine en finition avec le WINYL STYLUS DUO CLEAN.
Winyl One-Touch is a platinum vinyl diamond cleaner containing the latest generation of solid Polyurethane (PU) polymer and specially designed to...
