Refurbished product - Grade A
Brand new product. Original packaging is missing.
Adapter Female Jack 2.5mm to Male Jack 3.5mm Rhodium Plated Copper
This DD DJ35AR adapter is composed of a balanced female 2.5mm jack and a single-ended male 3.5mm jack. Enjoying a beautiful design quality, its contacts are Rhodium plated, a metal that resists perfectly to oxidation and corrosion. The "T" format of this connector allows it to occupy a small space once plugged. Its body is transparent, leaving the internal circuits visible for a modern design.
Product type | Jack adapter |
Connectors | 1x Female balanced Jack 2.5mm 1x Male single-ended Jack 3.5mm |
Contacts material | Copper |
Contacts plating | Rhodium |
Body material | PC Stainless steel |
Dimensions (without plug) | 13 x 10 x 8.5mm |
Connectic | Male & Female |
Connector | Jack 2.5mm |
Connector | Jack 3.5mm |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Rhodium |
Refurbished Grade | Grade A |
