Refurbished product - Grade S
Brand new product. 1m long version.
Hand-assembled in our workshops in France, the Audiophonics Greyhound Schuko to IEC C15 power cable offers an excellent solution for electrically connecting your HiFi equipment, ensuring clean and stable signal transmission. Based on Elecaudio and Viborg components using quality materials, the cable ensures that the electrical signal arriving at your audio equipment does not add unwanted noise.
The Audiophonics Greyhound is based on an Elecaudio CS-361B cable. It features three conductors made of OCC and OFC copper Litz wires and an OFC copper ground drain wire, ensuring excellent electrical conductivity. Each conductor is insulated with a PTFE sheath and the whole cable is double-shielded with aluminium foil and copper braid, effectively repelling interference.
The cable is terminated on the one hand with a male Viborg VE502G Schuko connector (Type E/F) and on the other hand with an Viborg VF502G IEC C15 connector. Both are high quality, with pure copper contacts and triple plating in OFC copper, silver and 24k gold for perfect conductivity and resistance to oxidation.
Product type | Power cable |
Connectors | 1* Male Schuko (Type E/F) 1* IEC C15 |
Length | 1m |
Cable conductors material | OCC / OFC copper |
Cable conductors section | 3x2.5mm² |
Cable conductors insulation | PTFE |
Cable double shielding | Aluminum foil Copper braid |
Cable outer sheath | PVC |
Cable diameter | Ø18mm |
Connectors contacts material | Pure copper |
Connectors contacts plating | OFC copper Silver Gold 24k |
Connectors diameter | Ø39mm |
Color | Cable: Silver Connectors: Silver and black |
Length (m) | 1.0 |
Shielding | Yes |
Section (mm²) | 2.5 |
Connector | Type E (CEE 7/5 - CEE 7/6) |
Connector | Schuko |
Connector | Type F (CEE 7/3 - CEE 7/4) |
Connector | IEC C15 |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Refurbished Grade | Grade S |
