[GRADE S] ELECAUDIO OMEGA 75 Coaxial Cable 75 Ohm OFC Copper Armored Ø6,7mm 1m
Refurbished product - Grade S
1m long pre-cut cable
With its expertise in the realization of customized Audio / Video cables, ELECAUDIO has imagined a 75 Ohm certified Coaxial cable capable of upsetting the established order as it uses materials and technologies usually reserved for products with very high prices, even inaccessible.
Reference : 16082
Refurbished
3,90 €tax incl.
3,25 € tax excl.
Brand new product. Length: 1m.
Elecaudio Omega 75
Elecaudio Omega 75 Câble Coaxial 75Ω Cuivre OFC Blindé Ø6.7mm 1m
This OMEGA 75 Coaxial cable in OFC Copper is intended for the High Fidelity lovers willing to upgrade their HiFi installation. It will be an excellent cable for DIY design of 75 Ohm certified audiophile cables, especially since a braided jacket is already applied on it for protection against external parasites and interferences.
Flexible and robust at the same time, this cable is composed of OFC copper conductors with PE insulation. The particular braiding of this cable allows a real insulation without the use of a sheath or a metallic strip which can raise the capacitive load and be harmful in the harmonics.
Product typeCoaxial cable
Length1m
Conductor materialOFC Copper
Section0.326mm² (22AWG)
Conductor resistance54.3Ω/km
Static capacity69pF
InsulationPE
Insulation diameterØ3.8mm
Covering sheathNylon tressé
Cable diameterØ6.7mm
Length (m)1.0
Number of conductors2
Insulation materialPE
ShieldingYes
Section (mm²)0.32
Refurbished GradeGrade S
Refurbished product - Grade S 1m long pre-cut cable With its expertise in the realization of customized Audio / Video cables,...
