By buying this product you get 76 loyalty points
Refurbished product - Grade S
This product is sold in the form of 1.7m offcut pieces of cable.
Interconnect Cable Balanced UP-OCC Silver 3x1.17mm² Triple Shielding 1.7m
The Neotech NEI-1001 is a balanced modulation cable made of 3 Silver UP-OCC conductors with a cross section of 1.17mm². Each conductor is composed of 4 strands of different sizes. The conductors are kept equidistant thanks to the use of PE tubes. The cable is covered by a PVC-jacket and covered with a nylon braided jacket.
Product type | Interconnect cable |
Conductors | UP-OCC Silver |
Conductors section | 3x 1.17mm² |
Shieldinh | Cu-Mylar foil Braided SPC PTFE tape |
Sheath | PVC |
Cover sleeve | Braided nylon |
External diameter | Ø11.5mm |
Length | 1.7m |
Diameter (mm) | 11.5 |
Length (m) | Sold by length |
Number of conductors | 3 |
Insulation material | PE |
Shielding | Yes |
Section (mm²) | 1.17 |
Conductors material (Cable) | Silver |
Conductors Plating (Cable) | None |
Refurbished Grade | Grade S |
Ground / Shielding | Yes |
