[GRADE S] NEOTECH NEMOI-3220 Balanced interconnect braided Cable OCC PTFE Ø10mm 3.7m
NEOTECH NEMOI-3220 Unbalanced interconnect braided wire OCC PTFE
Refurbished product - Grade S
The NEMOI series from Neotech is the result of extensive research in the field of audio cables. The Neotech NEMOI 3020 modulation cable is a combination of PTFE insulation and pure OCC copper conductors with a rectangular cross-section. It has a special architecture that greatly reduces the effect of inductance and capacitance.
Reference : 17473
Refurbished
110,63 €tax incl.
92,19 € tax excl.
Cable drop of 3.7m.
If you are looking for a high resolution cable, the Neotech NEMOI 3020 may fit the bill. The result is surprising, mixing qualities that are often contradictory, such as a solid bass and a legible, natural soundstage with a high definition in the midrange without auditive fatigue. The shielding can also be used as a conductor.
- Structure of the OCC Neotech NEMOI 3020 cable -
NEMOI-3320 Structure OCC Neotech
Characteristics:
  • 2 OCC Copper conductors with rectangular section + 1 copper shielding sheath
  • 3-layer insulation: PTFE and Polyethylene in second layer, PVC outer sheath
  • External diameter of the cable: 10mm
  • Length: 3.7m
Diameter (mm)10.0
Length (m)3.7
Number of conductors3
Insulation materialPTFE
ShieldingYes
Section (mm²)N/A
Refurbished GradeGrade S
Refurbished product - Grade S The NEMOI series from Neotech is the result of extensive research in the field of audio cables. The...
