Refurbished product - Grade S
90cm long pre-cut cable
This Neotech Nemos-1080 high-end speaker cable benefits from an all-inclusive design, incorporating the best possible components for maximum conductivity and optimal signal transmission, resulting in high quality sound reproduction.
This product is sold in the form of 90cm offcut pieces of cable.
Speaker Cable Pure OCC Silver 2.1mm² Ø12.5mm 90cm
This Neotech Nemos-1080 high-end speaker cable benefits from an all-inclusive design, incorporating the best possible components for maximum conductivity and optimal signal transmission, resulting in high quality sound reproduction. The cable incorporates 2.1mm² (14AWG) high purity rectangular OCC Silver conductors, individually insulated with PTFE jackets, and a 2.1mm² (14AWG) cross-section. Each pair of conductors benefits from additional PE insulation. Each pair of conductors has an additional PE insulation and is then sheathed with a PVC inner sheath and then an outer sheath, also made of PVC and transparent. In addition, the special design of the cable allows a strong reduction of the inductance and capacitance effect.
Product type | Speaker cable |
Conductors material | Pure OCC Silver |
Conductors section | 2.1mm² (14AWG) |
Insulation | PTFE PE |
External / internal sheath | PVC |
External diameter | 12.5mm² |
Color | Blue |
Length | 90cm |
Diameter (mm) | 12.5 |
Length (m) | 0.9 |
Insulation material | PTFE |
Insulation material | PE |
Section (mm²) | 2.1 |
Conductors material (Cable) | Silver |
Refurbished Grade | Grade S |
