1.9m long pre-cut cable
Refurbished product - Grade S
This product is sold in the form of 1.9m offcut pieces of cable.
Speaker Cable UP-OCC Copper Silver plated 8x1.3mm² Ø19mm 1.9m
The Neotech NES-3003 MKII loudspeaker cable is the result of today's recognized mastery in the use of OCC (Ohno Continuous Cast) copper, the Asian brand being the leader in integrating this advanced technology of copper treatment by liquid nitrogen and controlled cooling temperatures offering a purity of 99.9% ( 9N ).
The internal configuration of this cable is based on a hybrid structure of two conductors (black and white) on a particular topology and two others on another topology (red and black) cancelling the inductive and capacitive effects.
The special feature of the NEOTECH NES 3003 MK3 is the braided and strapped shielding, an original solution not found in other loudspeaker cable manufacturers and rarely used, which significantly reduces the noise without increasing the capacitance effects. The PVC sheath finishing the cable is fully antistatic treated.
The qualities of this cable are based on a perfect balance between timbre, seating and definition, which usually oppose each other. This is certainly one of the best performing cables on the market for any amateur who wants to increase the resolution of his Hifi system without sacrificing its balance and neutrality with a readability of the bass reinforcing the quality of the sound scene between the speakers.
To bi-wire your speakers, connect the red wire to the "+" terminal of the high midrange and the blue wire to the "-" terminal of the high midrange. The white wire should be connected to the "+" terminal on the bass and the black wire to the "-" terminal on the low end of your speakers.
Do not forget to remove the straps from the terminal blocks of your speakers in case of bi-wiring or bi-amplification.
Product type | Speaker cable (bi-wiring option) |
Number of wires | 4 (each of Ø5mm) |
Conductors material | OCC Silver plated OCC Copper |
Section | 9AWG / 6mm² |
Protection sheath | Internal : Polypropylene External : Anti-static PVC certified CL3 flame retardant |
Shielding | Metal braid |
Color | Metal gray |
Length | 1.9m |
Diameter (mm) | 19.0 |
Length (m) | 1.9 |
Number of conductors | 4 |
Insulation material | PVC |
Insulation material | PE |
Shielding | Yes |
Section (mm²) | 6.00 |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | Silver |
Refurbished Grade | Grade S |
Ground / Shielding | Yes |
