[GRADE S] NEOTECH NEVD-2001 Coaxial Cable 75 Ohm Pure Silver Quad shielding Ø7.6mm 50cm
Refurbished product - Grade S
The NEVD-2001 is an excellent Coaxial cable with an impedance of 75Ω, offering a wide bandwidth to reduce jitter and ensure maximum resolution. The cable benefits from an exceptional design, with a pure Silver conductor and a particularly effective quad shielding.
Reference : 16781
32,95 €tax incl.
27,46 € tax excl.
Cable drop of 50cm
Neotech NEVD-2001
Coaxial Cable 75 Ohm Silver Shielded 50cm
Neotech NEVD-2001 Câble Coaxial 75Ω Argent Blindé
Neotech's NEVD cable is carefully designed especially for the transmission of digital audio signals. The main characteristic of the digital audio signal is the transmission of very high frequencies. Therefore, the brand has particularly worked on minimizing the signal loss.
The NEVD-2001 is an excellent Coaxial cable with an impedance of 75Ω, offering a wide bandwidth to reduce jitter and ensure maximum resolution. The cable benefits from an exceptional design, with a pure Silver conductor and a particularly effective quad shielding consisting of Polyethylene foam, Copper-Mylar foil, microporous PTFE and SP-OFC braid.
Product typeCoaxial cable
Impedance75Ω
ConductorPure Silver
Quad ShieldingPolyethylene foam
Cu-Mylar foil
Microporous PTFE
Braided SP-OFC
Length50cm
Section (mm²)N/A
Conductors material (Cable)Silver
Refurbished GradeGrade B
Refurbished product - Grade S The NEVD-2001 is an excellent Coaxial cable with an impedance of 75Ω, offering a wide bandwidth to...
