Refurbished product - Grade B
Some scratches on the product.
Aluminium plate for Schuko Furutech plug FI-E30
We designed this all-aluminium wall plate to cover the Furutech plugs FI-E-30 (G) and FI-E-30 (R) and thus transform it into a complete wall socket. The centre distance of the fixing screws is compatible with wall socket boxes. Screws are sold separately.
Caution: Not all subbases are compatible with this plate. Please select the subbase models mentioned above.
Color | Black |
Thickness | 8mm |
Material | Massive Aluminium |
Holes spacing for flush-mounted box | 60mm |
Dimensions | 84 x 84mm |
Screws sold separately | Subbase fixation screws : 4x M4x6mm Wall plate fixation screws : 2x M3 x 20mm |
Furutech base to buy separately | FI-E-30 (G) or FI-E30 (R) |
Illustration with a Furutech FI-E30 (G)
(sold separately)
Max cable diameter (mm) | N/A |
Mounting type | N/A |
Connectic | N/A |
Connector | N/A |
Contacts Material (Connector) | N/A |
Contacts Plating (Connector) | N/A |
Refurbished Grade | Grade B |
