[GRADE B] DYNAVOX X2000 Filtered Power Strip 5 Schuko Sockets with Master-Slave Function
-20%
Refurbished product - Grade B
The X2000 is Dynavox's latest HiFi distributor, completing the X4100 and X7000 range. The X2000 takes up the basics again, this time with 5 Schuko sockets, an integrated phase detection system and a Master-Slave function. The latter will allow, if activated, to switch on all the devices connected to the ignition of one of them.
Reduced price!
Reference : 20562
Refurbished
Limited special offer
99,00 €tax incl.
-20%
79,00 €tax incl.
65,83 € tax excl.
Last items in stock !
Shipping date: 04-03-2025.
Scratches on plastic Schuko plugs.
Dynavox X2000
Dynavox X2000 Distributeur Secteur Filtré 5 Prises Schuko Fonction Master-Slave
The X2000 is Dynavox's latest HiFi distributor, completing the X4100 and X7000 range. The X2000 takes up the basics again, this time with 5 Schuko sockets, an integrated phase detection system (only for IEC input cable) and a Master-Slave function. The latter will allow, if activated, to switch on all the devices connected to the ignition of one of them. The X2000's sockets are also filtered, allowing you to deliver an electrical signal specific to your devices. A 10A circuit breaker allows it to protect your system in case of over-current. All components are housed in a robust brushed aluminium case.
Product typePower strip
Sockets typeSchuko
Number of sockets5
Filtering
Phase detection function
Input connectorIEC C14 (power cable included)
Input voltage / current230V/50Hz 10A
Integrated circuit breaker10A
Output power2300W (230V)
Housing materialBrushed Aluminium
Dimensions100 x 90 x 470mm
Weight2.6kg
Package1x Dynavox X2000
1x Power cable 0.75mm² 1.5m
Number of sockets5
FilteringYes
Refurbished GradeGrade B
Refurbished product - Grade B The X2000 is Dynavox's latest HiFi distributor, completing the X4100 and X7000 range. The X2000 takes up the...
