2.6m long pre-cut cable
By buying this product you get 33 loyalty points
Refurbished product - Grade S
This product is sold in the form of 2.6m offcut pieces of cable.
The FP-S032N is an ultra-high-performance 3-conductor power cable for uncompromising audio applications. Its build quality and technical features leave no doubt as to Furutech's premium positioning.
Each conductor consists of a central core made up of 1 x 37 strands of 0.25mm diameter OFC Alpha α copper, 2 x 37 strands of silver-plated copper, i.e. three times 2.5mm².
Each of these strands is individually insulated within a 3.4mm-diameter polyethylene sheath. The assembly is then double protected with a 12mm PVC inner sheath and a braided copper shield. This braided sheath comprises 9x24 strands of 0.12mm type Alpha α conductors.
As is standard practice for this manufacturer, all metals will have benefited from the proprietary Alpha α anti-magnetism process, itself based on 2 steps:
1 - Cryogenization of the metals by -250°C using liquid nitrogen, with the aim of consolidating their molecular structure and considerably improving their conductivity.
2 - Treatment of the same metals with a powerful magnetic field created by ring magnets, whose force of attraction is constantly monitored so as to leave no magnetic residue at the end of the treatment.
This second stage, developed in collaboration with the Japanese firm SEKIGUCHI MACHINE SALES, helps make FURUTECH cables exceptional conveyors for any electrical signal used in sound reproduction.
Specifications :
Diameter (mm) | 16.0 |
Length (m) | 2.6 |
Number of conductors | 3 |
Insulation material | PE |
Shielding | Yes |
Section (mm²) | 2.5 |
Connector | N/A |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Refurbished Grade | Grade S |
Ground / Shielding | Yes |
