By buying this product you get 22 loyalty points
Refurbished product - Grade A
Product in perfect condition. Heat-shrink tubing replaced.
Ethernet RJ45 Cable UP-OCC Silver 1m
Neotech offers with its NEET-1008 an excellent RJ45 Ethernet cable, benefiting from an exceptional design. It integrates four silver UP-OCC conductors with a cross-section of 0.258mm² (23AWG), ensuring perfect electrical conductivity and therefore signal transmission. Each conductor has a triple insulation consisting of an HDPE sheath and two aluminum-mylar foils. The assembly is then held together by a PVC sheath and covered with a white braided Nylon sheath.
Product type | Ethernet RJ45 cable |
Length | 1m |
Connectors | 2x RJ45 |
Conductors material | UP-OCC Silver |
Conductors section | 4x 0.258mm² (23AWG) |
Triple insulation | 1x HDPE sleeve 2x Aluminum-Mylar foils |
External sheath | PVC |
Covering sheath | Braided Nylon |
External dimensions | 4.2x 14.2mm |
Color | White |
Length (m) | 1.0 |
Shielding | Yes |
Section (mm²) | 0.258 |
Connector | RJ45 |
Conductors material (Cable) | Silver |
Conductors Plating (Cable) | None |
Refurbished Grade | Grade A |
