Neotech NEMOI-3220 Balanced interconnect braided cable
Refurbished product - Grade S
2.9m long pre-cut cable
The NEMOI series from the manufacturer Neotech is the culmination of long research in the field of audio cables. The Neotech NEMOI 3020 modulation cable, combining PTFE insulation and OCC pure copper conductors with a rectangular section, has a special architecture allowing a strong reduction in the effect of inductance and capacitance. If you are looking for a high resolution cable, the Neotech NEMOI 3020 can meet this expectation.
Reference : 18547
Refurbished
86,71 €tax incl.
72,26 € tax excl.
This product is sold in the form of 2.9m offcut pieces of cable.
NEOTECH NEMOI-3220
BALANCED INTERCONNECT BRAIDED CABLE OCC PTFE Ø10mm 2.9m
The result is surprising, combining listening qualities that are often contradictory, such as a seat in the bass and a readable, natural sound stage with High Definition in the midrange without auditory fatigue. The shield can also be used as a conductor.
- Cable structure OCC Neotech NEMOI 3020 -
NEMOI-3320 Structure OCC Neotech
Technical characteristics :
  • 2 OCC copper conductors with rectangular section + 1 copper shielding sheath
  • 3-layer insulation : PTFE and Polyethylene in second layer, PVC outer sheath
  • Cable outer diameter: 10mm
  • Length: 2.9m
Diameter (mm)10.0
Length (m)2.9
Number of conductors3
Insulation materialPTFE
ShieldingYes
Section (mm²)N/A
Refurbished GradeGrade S
Ground / ShieldingYes
[GRADE S] NEOTECH NEMOI-3220 Balanced interconnect braided Cable OCC PTFE Ø10mm 2.9m
Refurbished product - Grade S 2.9m long pre-cut cable The NEMOI series from the manufacturer Neotech is the culmination of long...
