2.5m long pre-cut cable
Refurbished product - Grade S
This product is sold in the form of 2.5m offcut pieces of cable.
The cross-insulation structure uses a layer of air as a shock absorber. This not only minimizes electrostatic stresses and preserves the definition of high frequencies, but also limits mechanical stresses. It is therefore a robust cable that can adapt to the specific geometry of your installations.
The strands are formed using natural diamond combs. This feature allows to produce smooth-surfaced strands and to maximize the conductor density while avoiding structural inaccuracies. The conductor structure is formed by a twisting process involving three different strand diameters. This results in a high density twisted structure ideal for all installations requiring a clean and precise signal.
The 102SSC precision conductor has been specially developed to deliver incredible sound quality. Its construction uses exclusively virgin copper. The manufacturer prohibits even the use of recycled copper to guarantee a driver of exceptional purity.
Diameter (mm) | 9.2 |
Length (m) | 2.5 |
Number of conductors | 2 |
Insulation material | PE |
Shielding | No |
Section (mm²) | 2.8 |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Refurbished Grade | Grade S |
Ground / Shielding | No |
