65cm long pre-cut cable
Refurbished product - Grade S
This product is sold in the form of 65cm offcut pieces of cable.
Power Cable 102SSC Copper Shielded 3x4mm² Ø13mm 65cm
The Oyaide Vondita power cable, sold by the meter, will allow you to design very high quality power cables, ensuring excellent electrical conductivity thanks to its high quality structure and materials. The cable has 3 twisted 102SSC copper conductors with a cross section of 4mm² each. These are insulated by a polyolefin sheath, and the whole is then shielded with a copper sheet. The whole is protected by a polyolefin sheath and covered with an external PVC sheath.
Product type | Power cable |
Conductors material | 102SSC Copper |
Section | 3x 4mm² |
Insulation material | Polyolefin |
Shielding | Copper foil |
External sheath | Polyolefin + PVC |
Outer diameter | Ø13mm |
Color | Red |
Length | 65cm |
Diameter (mm) | 13.0 |
Length (m) | 0.65 |
Number of conductors | 3 |
Insulation material | PVC |
Shielding | Yes |
Section (mm²) | 4.00 |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Refurbished Grade | Grade S |
Ground / Shielding | Yes |
