[GRADE A] DAYTON AUDIO BST-1 Speaker Driver Bass Exciter Bodyshaker 50W 4 Ohm 10Hz-80Hz
-12%
Refurbished product - Grade A
This Dayton Audio BST-1 exciter transmits the vibrations of the low frequencies to any supports on which they will be fixed. it will multiply tenfold the immersion of films with great spectacle. Under your sofa, your armchair, the Bass Shaker BST-1 is an indispensable accessory for any home theater lover and blockbusters.
Reduced price!
Reference : 19300
Refurbished
Limited special offer
55,90 €tax incl.
-12%
49,00 €tax incl.
40,83 € tax excl.
Torn cardboard packaging.
The Dayton Audio BST-1 will also be effective for video games and simulators. Several "Bass Shaker BST1" can be connected in parallel or series depending on the desired impedance.
Warning: Do not exceed 50 W RMS on 4 Ohm by BASS SHAKER multiplied by the number of Shaker: 50 x 4 = 200w RMS.
For a Bass Shaker, Class D amplifiers are ideal for increasing performance in a compact format.
Amplifier TDA7498 2 X 125 W.
Tripath Amplifier SMPS 2X90W
bass shaker BST 1 dayton audio
Features:/ Strong>
  • Applications: Home cinema, video games, Simulator etc.
  • Power requirement: 50 watts.
  • Impedance: 4 ohms.
  • Dimensions: Ø 147.30 mm x 56 mm (height)
  • Screws not included.
  • Weight: 1430 g
  • Mounting hole diameter: 100.94 mm
  • Quantity delivered: 1 piece.
Speaker Power (W RMS)50.0
Speaker TypeExciter
Impedance (Ω)4
Loudspeaker diameter (mm)147.0
Diaphragm typeN/A
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)N/A
Highest frequency (Hz)80
Refurbished GradeGrade A
Refurbished product - Grade A This Dayton Audio BST-1 exciter transmits the vibrations of the low frequencies to any supports on which they will...
