Refurbished product - Grade A
New product, never used. The carton is damaged and torn.
Radiateur Passif Aluminium 30.9Hz Ø10.2cm
The Dayton Audio DSA115-PR is a passive radiator that can be used in a wide variety of installations, whether as a speaker or as a replacement for a similar defective model. A built-in grounding disc ensures that the passive radiator will fit most applications, and an M5 thread allows you to add weight for a precise fit. The aluminum diaphragm and rubber suspension allows for a long linear excursion, while providing true ruggedness for long life.
The passive radiator (or passive loudspeaker) fits into a box with an active loudspeaker. This passive radiator, although it may at first glance look like a "classic" loudspeaker, does not in fact have any engine parts. Thus, its design does not include a coil, magnet and power supply. In the same way, it will not be electrically connected to a power amplifier.
To diffuse sound, the passive radiator will use the air pressures and depressions induced by the active loudspeaker in the cabinet to vibrate its diaphragm and restitute sound, thus providing deep bass. Its resonant frequency is determined by its mass and contained in the cabinet. Therefore, on many models, its resonance frequency can be varied and tuned to the speaker by adding mass.
Product type | Passive radiator |
Nominal diameter | Ø10.2cm (4") |
Resonant frequency (Fs) | 30.9Hz |
Mechanical quality factor (Qms) | 3.48 |
Compliance equivalent volume (Vas) | 0.33 ft.³ |
Mechanical compliance of suspension (Cms) | 2.27mm/N |
Diaphragm mass inc. airload (Mms) | 11.7g |
Max. linear excursion (Xmax) | 6mm |
Surface area of cone (Sd) | 54.1cm² |
Material | |
Cone | Aluminum |
Surround | Rubber |
Frame | Steel |
Mounting informations | |
Overall outside diameter | Ø11.56cm (4.55") |
Cutout diameter | Ø9.4cm (3.69") |
Depth | 3cm (1.17") |
Bolt circle diameter | Ø10.7cm (4.21") |
Number of mounting holes | 4 |
Weight | 159g |
Speaker Type | Passive Radiator |
Impedance (Ω) | NC |
Loudspeaker diameter (mm) | 102.0 |
Diaphragm type | Aluminium |
Efficiency / Sensitivity (dB) | N/A |
Max Linear Excursion (Xmax) (mm) | 6.0 |
Lowest frequency (Hz) | N/A |
Highest frequency (Hz) | N/A |
Refurbished Grade | Grade A |
