[GRADE A] DAYTON AUDIO HDN-8 Speaker Driver Exciter Bodyshaker Full Range Waterproof 50W 8 Ohm 40He - 15kHz Ø10.2cm
Refurbished product - Grade A
Vibrating electrodynamic seal, virtually anywhere this product allows the proper meaning to make "sound" any type of surface. The fixing of this product is carried out by screwing by means of the screw head molded in the loudspeaker.
Reference : 18289
Refurbished
24,90 €tax incl.
20,75 € tax excl.
Product in perfect condition. Carton packaging damaged.
Dayton HDN-8 Sound Exciter Waterproof vibrating speaker 8 Ohm
Vibrating electrodynamic seal, virtually anywhere this product allows the proper meaning to make "sound" any type of surface. The fixing of this product is carried out by screwing by means of the screw head molded in the loudspeaker. Its field of application is one where loudspeakers can not find place for visual reasons or for vandal protection concerns. This product is used as a conventional loudspeaker.
Features:
  • Power: 50 W
  • Impedance: 8 Ohm
  • Frequency response: 40 - 15,000 Hz
  • Net weight: 1kg
  • Waterproof: can be used in wet, outdoor, bathing, showers, etc.
  • Dimensions: 100 x 50 mm
Mounting examples
Speaker Power (W RMS)50.0
Speaker TypeExciter
Impedance (Ω)8
Loudspeaker diameter (mm)102.0
Diaphragm typeN/A
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)40
Highest frequency (Hz)15000
Refurbished GradeGrade A
Refurbished product - Grade A Vibrating electrodynamic seal, virtually anywhere this product allows the proper meaning to make "sound"...
