Refurbished product - Grade A
Product in perfect condition. Original cardboard packaging missing.
Aluminum housing 415 x 280 x 120 Front face 10 mm Black
HIFI 2000 housing Slimline serie have superb finish and are easy to assemble. The front fixation holes are drilled 45° to ensure a smooth profile with a very elegant effect once mounted.
Both side panels are made in aluminum and are 10mm thick, which allow some heat dissipation. Top and bottom panels are built in anti-scratch painted steel.
Spécifications | |||
Dimensions | Hauteur | Width | Depth |
Internal | 120 | 415 | 280 |
External | 122 | 435 | 291 |
Parts | |
Type | Self-assembly housing |
Front face | Aluminum (Black) 10mm thick |
Back panel | Aluminum (Black) 3mm Thick |
Side panels | Extruded Aluminum (Black) 10mm Thick |
Capot | Anti-sratch painted steel (Black) 1mm |
Pre-drilled for rack installation (19 inches) | No |
Poids | 4.7 kg |
Color | Black |
Material | Aluminium |
Internal width | 415 |
Internal depth | 280 |
Internal height | 120 |
Refurbished Grade | Grade S |
