[GRADE A] VIBORG VS703AG Pure Silver Spades Ø8.5mm (Set x4)
Refurbished product - Grade A
The Viborg VS703ag is a high quality fork for the design of high end speaker cables. They use a 99.98% pure silver conductor, ensuring maximum conductivity. The body of each fork is made of aluminum and carbon fiber, giving the whole an excellent durability.
Reference : 18192
Refurbished
169,00 €tax incl.
140,84 € tax excl.
Product in perfect condition. Box damaged and slightly torn.
Viborg VS703ag
Viborg VS703ag Fourches Argent Pur Ø8.5mm (Set x4)
The Viborg VS703ag are a high quality spades for the design of high end speaker cables. They use a 99.98% pure silver conductor, ensuring maximum conductivity. The body of each fork is made of aluminum and carbon fiber, giving the whole an excellent durability. The assembly is done simply with a double screw system allowing an effective maintenance of the cable.
Product typeSpades
Conductor materialPure silver (99.98%)
Shell materialAluminum and carbon fiber
Mounting typeTo screw
Max cable diameterØ8.5mm
U Size8mm
Total dimensions63*Ø14mm
Shell length34mm
Quantity4* spades (2* with red rings, 2* with black rings)
Max cable diameter (mm)8.5
ConnecticN/A
ConnectorSpade
Contacts Material (Connector)Silver
Refurbished GradeGrade A
Refurbished product - Grade A The Viborg VS703ag is a high quality fork for the design of high end speaker cables. They use a 99.98% pure silver...
