[GRADE B] DIY Box Power supply / Amplifier 100% Aluminium 311x221x150mm
Refurbished product - Grade B
This DIY 100% Aluminum large volume vented enclosure is ideal for integrating an amplifier or any other audio setup. Its robust design ensures efficient mounting and use with a professional finish.
Reference : 16801
145,00 €tax incl.
120,83 € tax excl.
Some scratches on the front panel of the case.
Dimensions Internal:
  • Working width: 213mm
  • Depth: 300mm
  • Working height: 142mm
External Dimensions:
  • Width: 220mm
  • Depth: 311mm
  • Height: 150mm
Box sold to assemble.
Specifications:
  • Solid Brushed Aluminum
  • Façade: 8 mm
  • Rear face: 3mm
  • Weight: 3kg
  • Supplied with screws, base and non-slip feet.
ColorSilver
MaterialAluminium
Internal width213
Internal depth300
Internal height142
Refurbished GradeGrade B
Refurbished product - Grade B This DIY 100% Aluminum large volume vented enclosure is ideal for integrating an amplifier or any other audio...
