[GRADE B] Dual Mono Power Amplifier Modules LM3886 2x120W 8 Ohm (Pair)
This dual mono amplifier is equipped with no less than 4 LM3886 amplification chips in total, to deliver 2x120W at 8 Ohms and accompany your hifi system as required.
Reference : 17776
Refurbished
149,00 €tax incl.
124,16 € tax excl.
One corner of a PCB is slightly damaged.
Double Mono LM3886 amplifier modules
2x120W 8Ω
Module amplificateur double mono LM3886 2x120W 8 Ohm (La paire)
LM3886 + AOP NE5532D
This amplifier is composed of two mono modules, each integrating 2 LM3886 amplification chips in Class AB, coupled to 2 AOP NE5532D mounted on DIP8, for a total of 4 amplification chips. With these components, the amplifier is capable of delivering 2x120W under 8Ω to efficiently power your audio system.
Double Mono design & pure DC amplification
The dual mono design (one channel per module) allows to separate the power supplies to obtain a cleaner current, to limit crosstalk and to obtain a much more aerated sound image.
To ensure true separation, each channel uses a high-gain Op Amp. This architecture results in deeper bass and dynamic high frequencies.
Speaker protection & Balanced architecture
Each module integrates a loudspeaker protection circuit using an Omron relay. Your high-end speakers have nothing to worry about with this amplifier.
In addition, to ensure high signal accuracy and noise reduction, these modules are based on a symmetrical architecture.
Quality components
Each module integrates high quality components, contributing to the sound quality of the product. For example, there are ELNA, Nover capacitors or an Omron relay.
It is recommended to install a heat sink on the amplifier chips.
Amplification chipLM3886
Power2x120W 8Ω
Power supply24V-0-24V + 15V-0-15V
InputsXLR
RCA
OutputsSpeaker terminal
AOP2x NE5532D
Dimensions (1 module)170*83*40mm
Weight280g/module
InputXLR
OutputSpeaker terminal
Channel1 (Mono)
ClassClass A / AB
Amplifier chipLM3886
Power (W)120.0
Refurbished GradeGrade B
Produit reconditionné - Grade B This dual mono amplifier is equipped with no less than 4 LM3886 amplification chips in total, to...
