[GRADE B] MUNDORF N300 Zero Ohm Self Coil 10mH
-37%
Refurbished product - Grade B
The Zero Ohm Coil (ZOC) is a transformer sized coil. It is made of Feron, a high quality material that limits the induced distortion to a maximum. In the ZOC, the center space is calibrated and adjusted by hand between the two laminar cores.
Reduced price!
Reference : 17479
Refurbished
Limited special offer
235,00 €tax incl.
-37%
149,00 €tax incl.
124,17 € tax excl.
Last items in stock !
Shipping date: 23-04-2025.
Broken plastic support (view photos).
Mundorf N300
Self Zero Ohm Coil 10mH
Mundorf N300 Self Bobine Zéro Ohm
The Zero Ohm Coil (ZOC) is a transformer sized coil. It is made of Feron, a high quality material that limits the induced distortion to a maximum. In the ZOC, the center space is calibrated and adjusted by hand between the two laminar cores (one L-shaped, one E-shaped). The volume of the center gap determines the inductance of the coil and requires great care in the manufacturing process. It must not be too thin, otherwise saturation effects could occur at high load. These coils are recommended for filtering bass speakers. Their low impedance allows to improve the impulse response (better speaker behaviour).
Product typeZero Ohm Coil
ToleranceMax. 5%
CoreFeron
Conductor materialOFC Copper (purity : 99.99%)
Inductance10mH
Impédance0.07 Ohm
Dimensions106 x 94 x 88mm
Inductance (mh)10.0
Refurbished GradeGrade B
Refurbished product - Grade B The Zero Ohm Coil (ZOC) is a transformer sized coil. It is made of Feron, a high quality material that limits the...
