[GRADE S] IEC C14 Socket with ON-OFF Switch and 250V Fuse Slot Black
Refurbished product - Grade S
This IEC C14 header is ideal for integration into a DIY device as a power connector. The header has a built-in ON/OFF toggle switch for powering your device and a fuse slot to protect your system.
Reference : 16357
Refurbished
2,50 €tax incl.
2,08 € tax excl.
Brand new product.
IEC C14 Socket
With ON-OFF Switch and 250V Fuse Slot Black
Embase IEC C14 avec interrupteur à bascule ON-OFF et emplacement fusible 250V 10A noir
The 250V fuse is sold separately.
Product typeIEC C14 Socket
ON-OFF Switch
Fuse slotFuse sold separately
Voltage / Current250VAC 10A
Total dimensions66 x 31.5 x 34mm
Cutout dimensions27 x 46.7mm
Mounting holes spacing55.7mm
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
ConnectorIEC C14
Contacts Plating (Connector)Nickel
Refurbished GradeGrade S
Refurbished product - Grade S This IEC C14 header is ideal for integration into a DIY device as a power connector. The header has a built-in...
