Very small, low profile plugs. These would be good in non-critical applications. The positive can accept up to 16awg wire. There is not a great place to solder the ground side, so a little dexterity is needed. I wouldn't recommend trying to use wire larger than 18awg. 16awg can be used (depending on insulation thickness) if you bore out the back of the plastic shell, but I wouldn't recommend it. Overall, the price makes them worth a shot since there's little to lose. It's nice to have options available in addition to the more expensive (but better) Oyaide & Elec Audio plugs.
![[GRADE A] DAYTON AUDIO DSA215-8 Speaker Driver Woofer 80W 8 Ohm 89dB 35Hz - 7000Hz Ø20cm](https://www.audiophonics.fr/72887-medium_default/dayton-audio-dsa215-8-speaker-driver-woofer-80w-8-ohm-89db-35hz-7000hz-o20cm.jpg)
