[GRADE S] WBT-0702.01 Speaker Terminals Gold Plated Copper (Pair)
Refurbished product - Grade S
The integrated retaining mechanism (WBT patent) holds the banana plug firmly in place when the front locking nut is tightened and thus not only protects the connection against accidental disconnection but also ensures extremely high contact pressure.
Reference : 16054
Refurbished
134,50 €tax incl.
112,08 € tax excl.
New product, sold by the pair.
WBT-0702.01
WBT-0702.01 Borniers pour Haut-Parleur Plaqué Or (La paire)
Since it is known that a simple electrical wire is no longer sufficient to connect an amplifier and speakers, we have become accustomed to using cables with large cross sections, which has had some repercussions on the terminal blocks. There are two requirements for this type of connector: it is not only a question of accepting large cable cross-sections, but above all of ensuring excellent conductivity by means of extreme tightening. The truth is therefore not in the giant terminal blocks, but rather in the mechanical design of the connector, which is extremely robust.
Product typeSpeaker terminals
MaterialCopper (68%) Alloy
PlatingGold 24k
ConceptionMachined in the mass
Max support thickness10mm
LengthSpeaker terminal: 31mm
Total length (avec pas de vis) : 58mm
Max. speaker terminal diameterØ21mm
Weight (per speaker terminal)60g
Package2x Terminal WBT-0702.01
Mounting typeTo screw
ConnecticFemale
Max panel thickness (mm)10.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
Refurbished GradeGrade S
Refurbished product - Grade S The integrated retaining mechanism (WBT patent) holds the banana plug firmly in place when the front...
