Dayton Audio BST-2 Exciter
Refurbished product - Grade A
The Dayton Audio BST-2 transducer lets you feel those low frequencies without the need for an oversized subwoofer and extremely high sound pressure level. By mounting it on a chair or sofa, you can create a more immersive experience by augmenting the existing low-frequency output from your speakers or headphones with powerful tactile feedback.
Reference : 18535
Refurbished
32,90 €tax incl.
27,42 € tax excl.
Product in perfect condition. Torn cardboard box.
Dayton Audio BST-2
Speaker Driver Exciter Bass Shaker 35W 4Ohm 10Hz-80Hz
Dayton Audio BST-2 Haut-Parleur Vibreur Exciter 35W 4Ω 10Hz-80Hz
The human ear has the ability to hear a wide range of sounds, however, some sounds are simply too low to be heard and must be felt by the body. Feeling these extremely low frequency sounds adds a new dimension to your listening, playing and movie experiences.
The BST-2 is equipped with 4 mounting holes for easy installation on any flat surface. The mounting plate includes a foam gasket to ensure that there is no hum, even in the event of intense vibration. A dual suspension system keeps the mass moving linearly to provide incredible tactile feedback without unwanted noise. Excess heat from the voice coil is dissipated by the rugged cast aluminum housing for long life and reliable performance.
Additional Notes and Suggestions :
  • A low-pass filter of 80Hz or less is recommended to reduce unwanted high-frequency output.
  • Recommended amplifiers: Dayton Audio SA70 for one to two BST-2 vibrators. Dayton Audio APA150 for four BST-2 vibrators (wired in series-parallel for a load of 4Ω). Dayton Audio BSA-200 for six BST-2 vibrators (wired in series-parallel for a load of 6Ω).
Product typeExciter (Bass Shaker)
Frequency response10Hz - 80Hz
Resonant frequency (unmounted)30Hz
Impedance4Ω
Power handling35W RMS
Peak force11.34kg / 30.48cm (25lbs. per ft.)
Housing materialAluminum
DimensionsØ130.8 x 54.9mm
Mounting circle diameterØ127mm
Weight1.18kg
Speaker Power (W RMS)35.0
Speaker TypeExciter
Impedance (Ω)4
Loudspeaker diameter (mm)130.0
Diaphragm typeN/A
Efficiency / Sensitivity (dB)102.0
Efficiency / Sensitivity (dB)93.0
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)10
Highest frequency (Hz)80
Refurbished GradeGrade A
[GRADE A] DAYTON AUDIO BST-2 Speaker Driver Exciter Bass Shaker 35W 4Ohm 10Hz-80Hz
Refurbished product - Grade A The Dayton Audio BST-2 transducer lets you feel those low frequencies without the need for an oversized subwoofer...
