Refurbished product - Grade A
Original cardboard packaging missing.
The Dayton Audio EX32VBDS-4 exciter has been meticulously designed to optimize performance in the often challenging low-frequency spectrum. This state-of-the-art exciter exceeds the limits of its counterparts, while preserving high-frequency reproduction. With its simple 4Ω load and 40W power handling, the EX32VBDS-4 integrates effortlessly into a wide range of audio projects.
The vibrator, 32mm in diameter, has the ability to turn almost any surface into a loudspeaker. A neodymium magnet is used to create maximum magnetic flux around the proprietary coil for enhanced sensitivity compared with similar-sized exciters. However, the EX32VBDS is optimized to reproduce the low frequencies often missing with vibrators.
Thanks to Dayton Audio's exclusive IMS interchangeable mounting system, you can try out numerous configurations and placements for your project. Each vibrator comes with a threaded mounting cap that can be permanently installed anywhere. Installation is easy: simply remove the cap from the vibrator, mount it on your project with 2 screws or 3M adhesive, and screw the vibrator assembly back onto the cap.
Product type | Exciter |
Impedance | 4Ω |
DC resistance (Re) | 3.6Ω |
Voice coil inductance (Le) | 0.43 @ 10kHz |
Resonant frequency (Fs) | 85.4Hz |
Total quality factor (Qts) | 0.75 |
Voice coil diameter | 32mm |
Total dimensions | 84 x 95.7 x 41.2mm |
Speaker Power (W RMS) | 40.0 |
Speaker Type | Exciter |
Impedance (Ω) | 4 |
Loudspeaker diameter (mm) | 84.0 |
Diaphragm type | N/A |
Efficiency / Sensitivity (dB) | N/A |
Max Linear Excursion (Xmax) (mm) | N/A |
Lowest frequency (Hz) | N/A |
Highest frequency (Hz) | N/A |
Refurbished Grade | Grade A |
