Refurbished product - Grade B
Product in perfect condition. Original box missing.
A weatherproof electrodynamic exciter that can be placed virtually anywhere, Dayton Audio's HDN-8 literally makes any surface "ring". The product is screw-mounted using the screw head molded into the speaker. It's ideal for applications where speakers can't be placed for visual reasons, or for outdoor locations, or for vandal-proofing. In fact, thanks to its hermetically sealed design, it can be easily integrated into an indoor bathroom or outdoor terrace. The large-thread metal stud is easy to install in wood, fiberglass or plastic. This product can be used like a conventional loudspeaker, thanks to its 8-ohm impedance.
KEY POINTS :
Technical charcteristics
Product type | Sound Exciter |
Output power | 50Wrms |
Impedance | 8Ω |
Fréquency response | 40Hz-15kHz |
Weatherproof |
Net weight | 1kg |
Dimensions | Ø100 x 50 mm |
Color | Black |
Package | 1x DAYTON AUDIO HDN-8 Speaker Driver Exciter |
Speaker Power (W RMS) | 50.0 |
Speaker Type | Exciter |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 102.0 |
Diaphragm type | N/A |
Efficiency / Sensitivity (dB) | N/A |
Max Linear Excursion (Xmax) (mm) | N/A |
Lowest frequency (Hz) | 40 |
Highest frequency (Hz) | 15000 |
Refurbished Grade | Grade B |
