[GRADE S] Heat-shrink tubing 2:1 Ø05mm Blue 70cm
Refurbished product - Grade S
1m long pre-cut sheath
Reference : 18788
0,63 €tax incl.
0,53 € tax excl.
This product is sold in the form of 70cm offcut pieces of cable.
Thermo-retractable sheath with a ratio of 2: 1.
Thickness of intermediate size studied to provide excellent protection to mechanical strength, while maintaining a high degree of flexibility.
Adapts to irregular shapes and provides a high degree of insulation and waterproofing. Product is halogen-free, flame retardant, and RoHS certified.
A ratio of 2: 1 means that the diameter of the sheath once heated will be divided by 2: for example for a 12mm sheath, after being heated its diameter will be 6mm.
Diameter: 5mm => about 2.5mm after retraction
https://www.audiophonics.fr/images2/GAINES-THERMO_1.jpg
Specifications:
  • Retractable Ratio: 2: 1
  • Longitudinal Retracting Ratio: ± 8%
  • Shrink Temperature: 70 - 115 ° C
  • Sheath Thickness Retractable : +/- 0.15mm
  • Sheath Thickness After Shrinkage : +/- 0.22mm
  • Temperature Resistance: -45 to + 125 ° C
  • Rigidity Dielectric: ≥15 Kv / mm (IEC243)
  • Certifications: RoHS
  • Diameter: 5 mm
  • Length: 70cm
  • Colors Blue
ColorBlue
MaterialN/A
Length (m)0.7
Max cable diameter (mm)5.0
Refurbished GradeGrade S
Refurbished product - Grade S 1m long pre-cut sheath
