Refurbished product - Grade B
Galaxy housings are small models particularly suitable for mounting active filters, preamplifiers, etc. The internal useful height is 80mm.
Scratches on the lower cover.
Aluminum Housing 210 x 280 x 80 Front face 3 mm Black
This HIFI 2000 housing Galaxy GX288 in aluminum / steel is a great solution for your DIY projects.
Elegant and long-lasting, it provides excellent protection for your device electronic components. It has air holes on its top cover to allow the air to circulate and dissipate the heat. The GALAXY serie by HIFI 2000 counts small and medium-sized housings which are ideal for active filters, preamplifiers...etc.
Specifications | |||
Dimensions | Height | Length | Width |
Internal | 80 | 210 | 280 |
External | 84 | 230 | 291 |
Parts | |
Type | Self-Assembly Housing |
Front face | Aluminum 3mm thick |
Back face | Aluminum 3mm thick |
Side covers | Aluminum extruded 10mm thick |
Top & bottom covers | Steel 2mm |
Weight | 2 kg |
Color | Black |
Material | Aluminium |
Internal width | 210 |
Internal depth | 280 |
Internal height | 80 |
Refurbished Grade | Grade B |
