VIBORG VE512R Schuko Power Connector Pure copper Silver / Rhodium Plated Ø20mm
Refurbished product - Grade B
The VE512R serie power connectors are designed to for high quality power cables assembly. They have a robust clamping system which ensures great stability from 6 to 20mm⌀ and are therefore quite suitable for HiFi cables with a large diameter.
Reference : 16787
69,90 €tax incl.
58,25 € tax excl.
Scratches on the ground contact.
VIBORG VE512R
A pure copper conductor with triple plating (respectively: OFC Copper, Silver and Rhodium) ensures superior conductivity that will enhance the qualities of a well-built power-supply, benefiting all subsequent elements of the installation.
Finally, the assembly is protected by a lightweight aluminum housing with a elegant design. This material also limit any EMI / RFI interference that might impair the signal.
Connector TypeSchuko male
Contact materialspure copper
Max cable diameter6-20mmØ
Plating contacts1. OFC copper
2. Silver
3. Rhodium
Max conductors dimensionsDiameter: 4.5mm
Section: 15.90mm²
AWG: 5
Voltage / CurrentAC 250V / 16A
Dimensions79.5x40mm / Length 98.6mm
ScrewHex / Phillips
ColorMoney
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)16.0
Refurbished GradeGrade B
Refurbished product - Grade B The VE512R serie power connectors are designed to for high quality power cables assembly.  They have a...
